Hi there. I've got a couple 525G2s - and trying to pair different headsets via bluetooth. After trying to pair, and not having my headsets detected, the handset then fails to work - no audio at all. Even after a factory reset.
I have been trying for 3 days to get any of the VPN client to site options on our RV340 to work. I have tried SSL VPN, L2TP, Client to Site... I have followed the directions provided by Cisco but there is no response at all when I try to conne...
view more
Hi, SG350-20 "System Summary" unresponsive with firmware release 2.5.7.85 ( just "processing data" ). I have tried after factory reset also , but the result is the same.I had switch back to 2.5.5.47. Any suggestions ?BR, VB
In the static NAT under firewall I am trying to create NAT rule where when I give the static IP in public IP range tab I am getting error as it is the WAN IP of WAN2. How can I create NAT then. Please help.
