Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2216
johewitt
How to turn OFF status LED on VC220?
I'm looking for a way to turn off the status LED on a VC220.  This is not the IR LED, but instead the large blinking LED on the front.
The documentation mentions that it can be turned off, but I can't find a menu option for this.
Thanks for your help!
--Joe
Status LED
Indicates the following status:
LED Off—The power is off or the LED status is turned off.
Flashing green in one second intervals—The camera and network is functioning.
Steady orange—The camera can’t detect a networking signal; thus the camera is not functioning. For example, the Ethernet cable is not attached.
Flashing orange—The PIR sensor noted movement. Flashing green rapidly—The firmware is being
upgraded.
Flashing orange rapidly—The camera’s default settings are being restored.
Alternating flashing green and orange—Video has been lost.
1 ACCEPTED SOLUTION
jasbryan
Frequent Contributor
Joe,
Use the Network Setting > IP Setting page to set the IP address and other related
settings. When you complete the configuration, click Save to save the settings;
otherwise click Cancel to discard the changes.
Disable LED Operators—Select to disable the LED illuminators. You may
choose to do this if you don't want to alert others that the network camera is
on. Use the Network Setting > IP Setting page to set the IP address and other related
http://www.cisco.com/en/US/docs/security/csbvsc/vc220/administration/guide/VC220AdministrationGuide.pdf
page; 41
Hope this is what you're looking for,
Jasbryan
2 REPLIES 2
jasbryan
Joe,
page; 41
Jasbryan
Thanks Jasbryan!  I can't believe I overlooked that option.  I thought that checkbox was referencing the IR LEDs.
Your help is much appreciated!
