Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2922
clifford.gormley
Beginner
Simple question. Hard to find an answer. Threshold setting on WVC2300
Hello
I have a WVC2300
What is the most sensitived setting, a plus or a minus - ???
Come on Cisco, update your documentation!
1 ACCEPTED SOLUTION
mpyhala
Rising star
Hi Clifford,
Thank you for posting. It has been a long time since I played with those settings but if I remember correctly the - side means more sensitivity. Also, I found the following in the WVC210 Admin Guide which appears to confirm this:
Adjust the sensitivity of each window by using the threshold slider (less threshold
means more sensitivity)
2 REPLIES 2
mpyhala
Rising star
Hi Clifford,
Thank you!
