Small Business Video Monitoring System - error
weakestlink
Beginner
Beginner
I have upgraded SWVMS to version 2.0.1.28 and when I launch the Main Console, I get the following error:
Some files are missing or corrupted. Please re-install the system to solve this problem. (Error Code:268435457)
The program then stops to run and exits.
I am running Win7 Home Premium linked to a 1360x768 screen (if that helps).
Please help!
4 REPLIES 4
search that error in this community.  You will find lots of things to try, starting with resolution....
Thanks..
Yes I have searched and only found answers referring to resolution. Thats the reason why I posted mine in my question..
Searching that code turns this message up as the top link and the other links seem unrelated to this product.  I have tried several resolutions for the desktop but I continue to get the same error code and cannot use the software.  Any advice or at least a link to these other posts would be helpful.
ihannich
Beginner
Beginner
Try this link to see if it helps (workarounds for Windows 7): http://www.cisco.com/en/US/docs/security/csbvsc/swvms16/tech_note/SVWMS_Windows7_AN.pdf
