WVC210 - problem with playback system.
tsunamisurfing
Beginner
Beginner
Hi all,
someone can tell me where is my mistake??
When I try to view my video recording (stored in local compuer) in the windows just appears an static image of the first image recorded.
In this image, on the top right corner, appears a disable icon camera and I can't go on. (What's does it mean??)
I have installed last software (AVMS_APP_2.0.2.1.zip) and using WIN7 professional 64 bit. I try to disable UAC too.
The camera work fine and is conneted by wireless connection with static IP. I can view the streaming on IE and Main Console regularly.
Tanks all.
6 Replies 6
Eric Moyers
Rising star
Rising star
Thank you for your question.
My name is Eric Moyers, I am a Cisco Smal Business Support Engineer. Couple of questions,
1.) What camera are you using?
2.) What do you have the the Video settings set to?
3.) Has this ever worked, or has it always been this way?
If possible you should probably call into the Support Center ao one of a Agents can go over the settings you have in the software. Would be quicker that way.
Eric Moyers
Cisco SBSC Network Engineer
1-866-606-1866
Hello mr. Moyers and thanks for your fast anwer.
Following my answer:
CISCO WVC210 PTZ with all lastes software/firmware installed.
I have try to change in all format (MJPG, MPEG4) 640 x 480 resolution. Not resolve.
Yes, it worked before with same configurations. I've just installed the last software (AVMS_APP_2.0.2.1).
Great. Where i can find this contact?
More informations about my system:
Machine: DELL Laptop, I7 processor, 4 Gb ram, win7 Pro 64 bit
ESET Smart Security suite antivirus
Configuration IP camera: WEP wireless with static IP. It works fine trought I.E.
Storage: Local Machine
The Support Center here in the US is 1-866-606-1866. It is open 24 hrs a day 7 days a week, even Holidays.
For other locations please check this list
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Hello again Eric,
I try to contact service at:
Italy800 928 322
but i didn't get nothing...
I just ask to CISCO what hell means the icon on the top... It's so difficult??
Tks.
Deart CISCO staff,
I finally found myself an answer to my question.
To able all recorded events I just flag "auto skip in rec movement" in VIDEO MONITORING SYSTEM -> SETTING -> general -> player.
If this is disable, the player shows nothing, despite some event are present on local server. The icon on the top right corner (camera disable) means that no event is occours at moment. (The long awaited answer to my question).
Tanks a lot for all your "FANTASTIC" support!!!! I'm aware that CISCO is always the best!!!
I hope my solution will help other desperate customers...
tsunamisurfing,
Your solution will help other desperate customers...
I have personally never experienced the issue you had. Now I know what to do if it happens.
Thank you for posting!
Recognize Your Peers
