Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2781
clifford.gormley
Beginner
WVC2300 Motion Detection Threshold
Does a '-'  (minus) in the Threshold bar indicate that it is more sensitive, or does it indicate that it is less sensitive?
You think Cisco would have mentioned that in the Online Help.
1 ACCEPTED SOLUTION
Eric Moyers
Rising star
Hello Sir,
This adjustment always makes me have to stop and think. If I remember correctly it is opposite of the way it looks on the settings. Closer to the "-"means more sensitive or the "less" it takes to activate the motion. Of course then the "+" meas=ns the less sensitive or the "more" it takes to activate the motion.
Hope this helps
Eric Moyers
2 REPLIES 2
Eric Moyers
Rising star
Hello Sir,
Hope this helps
Eric Moyers
Thanks Eric,
That is what I think too.
I guess you may want to decrease the sensitivity for Motion Detector Windows where shadows (the sun movement causes shadow changes, tree movement shadows,) etc. are caused.
I have found that flat surfaces can be real sensitive to pick up shadows as motion, so I have moved my Motion Detection Windows away from walls, doors, etc. that have predominately flat surfaces.
