CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1101
Highlighted
Beginner
3rd VLAN interface doesn't add correctly
Hi there,
I'm having some difficulties with a 300 series switch running in L3 mode. I've created two VLANs each with an IP interface both of which are working fine without any problems. The problem I have is when additing a third VLAN and IP interface - for some reason the switch doesn't seem to add the subnet into its routing table as a directly connected route.
The first and second VLANs add correctly. It seems to be the third. I've factory defaulted the switch and still the same. Version is 1.1.2.0.
Setup is as follows:
VLAN1 - 10.20.2.253/24
VLAN2 - 192.168.2.253/24
VLAN3 - 192.168.3.253/24
Ping results are:
switch27b42e#ping 10.20.2.253
Pinging 10.20.2.253 with 18 bytes of data:
18 bytes from 10.20.2.253: icmp_seq=1. time=0 ms
18 bytes from 10.20.2.253: icmp_seq=2. time=0 ms
18 bytes from 10.20.2.253: icmp_seq=3. time=0 ms
18 bytes from 10.20.2.253: icmp_seq=4. time=0 ms
----10.20.2.253 PING Statistics----
4 packets transmitted, 4 packets received, 0% packet loss
round-trip (ms) min/avg/max = 0/0/0
switch27b42e#ping 192.168.2.253
Pinging 192.168.2.253 with 18 bytes of data:
18 bytes from 192.168.2.253: icmp_seq=1. time=0 ms
18 bytes from 192.168.2.253: icmp_seq=2. time=0 ms
18 bytes from 192.168.2.253: icmp_seq=3. time=0 ms
18 bytes from 192.168.2.253: icmp_seq=4. time=0 ms
----192.168.2.253 PING Statistics----
switch27b42e#ping 192.168.3.253
Pinging 192.168.3.253 with 18 bytes of data:
PING: net-unreachable
----192.168.3.253 PING Statistics----
4 packets transmitted, 0 packets received, 100% packet loss
Further output that may be of interest:
switch27b42e#show ip int vlan 1
    IP Address         Type     Directed   Precedence   Status
                                Broadcast
10.20.2.253/24      Static      disable    No         Valid
switch27b42e#show ip int vlan 2
                                Broadcast
192.168.2.253/24    Static      disable    No         Valid
switch27b42e#show ip int vlan 3
                                Broadcast
192.168.3.253/24    Static      disable    No         Valid
switch27b42e#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding:          enabled
Codes: C - connected, S - static, D - DHCP
C  10.20.2.0/24       is directly connected                        vlan 1
C  192.168.2.0/24     is directly connected                        vlan 2
What am I doing wrong?
Thank you in advance.
Craig
1 ACCEPTED SOLUTION
Rising star
Hi Craig,
I don't think your doing anything wrong.
The route command shows that that IP interface for  VLAN3 is not connected, or at least nothing is physically plugged into VLAN3.
Plug a PC into VLAN3 and see if the interface route comes up.
I am just guessing that nothing is physically plugged into vlan3.
regards Dave.
2 REPLIES 2
Rising star
Hi Craig,
regards Dave.
Beginner
Simple as that!
I've just set a port into the VLAN and it now appears in the routing table. I'm kicking myself for not spotting it!
Thanks for your help.
