05-04-2018 03:44 AM - edited 03-21-2019 11:24 AM
I'm trying to bind ACL to a VLAN, but keep getting this error: Cannot apply because lack of hw resources
I've had a look online and it says it's a bug and to use textual config, but I'm not sure how this is done.
Does anyone know of an online tutorial, or perhaps a fix for this?
Rich
05-10-2018 10:16 PM
Hi Rich,
Thank you for writing to Cisco forums.
Firstly, make sure that you are using the latest firmware and bootcode of the switch.
Also kindly follow the below procedure to bind an ACL to a VLAN
STEP 1 Click Access Control > ACL Binding (VLAN).
STEP 2 Select a VLAN and click Edit.
If the VLAN you require is not displayed, add a new one.
STEP 3 Select one of the following:
• Select MAC Based ACL—Select a MAC-based ACL to be bound to the
interface.
• Select IPv4 Based ACL—Select an IPv4-based ACL to be bound to the
interface.
• Select IPv6 Based ACL—Select an IPv6-based ACL to be bound to the
interface.
• Default Action—Select one of the following options:
- Deny Any—If packet does not match an ACL, it is denied (dropped).
- Permit Any—If packet does not match an ACL, it is permitted
(forwarded).
NOTE Default Action can be defined only if IP Source Guard is not activated
on the interface.
STEP 4 Click Apply. The ACL binding is modified, and the Running Configuration file is
updated.
NOTE If no ACL is selected, the ACL(s) that is previously bound to the VLAN are unbound.
05-18-2018 08:35 AM
Thanks for replying, I've done the firmware upgrade, but it's still the same:
