Anyconnect SSL VPN on RV340 "hanging up"
dharric123
Folks,
I have an RV340 as an Anyconnect SSL VPN server. I can successfully connect and disconnect  twice with a mobile client. However on teh third attempt to connect, I reach the server, accept the banner, but the VPN disconnects. Logs are attached.
 I will appreciate any assistance that I can get is resolving this issue.
Sujoy Paria
Can you please verify the log on the RV340 Router, whether you are able to see any log which shows 'QueueNotEmpty : queue entries is empty'
 Also please confirm the Firmware version running on the RV340 Router.
Apologies for my late reply
The firmware version is 1.0.01.18.
I am seeing *QueueNotEmpty : queue entries is empty *in the logs
Thank you for your reply. The mentioned problem has already been reported (for the mentioned firmware version) and there is a bug CSCvj50141 generated for the same.
Presently the workaround are as follows…
-  Only known workaround is to reboot the router
-  Sometimes changing port used has helped
The mentioned bug might get fixed on the future firmware release.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
