CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
526
Beginner
Anyconnect SSL VPN on RV340 "hanging up"
Folks,
I have an RV340 as an Anyconnect SSL VPN server. I can successfully connect and disconnect  twice with a mobile client. However on teh third attempt to connect, I reach the server, accept the banner, but the VPN disconnects. Logs are attached.
 I will appreciate any assistance that I can get is resolving this issue.
4 REPLIES 4
Highlighted
Re: Anyconnect SSL VPN on RV340 "hanging up"
Can you please verify the log on the RV340 Router, whether you are able to see any log which shows 'QueueNotEmpty : queue entries is empty'
 Also please confirm the Firmware version running on the RV340 Router.
Beginner
Apologies for my late reply
The firmware version is 1.0.01.18.
I am seeing *QueueNotEmpty : queue entries is empty *in the logs
Thank you for your reply. The mentioned problem has already been reported (for the mentioned firmware version) and there is a bug CSCvj50141 generated for the same.
Presently the workaround are as follows…
-  Only known workaround is to reboot the router
-  Sometimes changing port used has helped
The mentioned bug might get fixed on the future firmware release.
