Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2602 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4134 Views
  • 1 replies
  • 16 Helpful votes
Folks  I m super frustrated. i thought by getting the cisco RV340 router  it will solve my problem by allowing me to create a static NAT for my private vLANs to access internet.when connecting the RV340 router i got my ISP IP and created the needed v...
VMwareLab by Level 1
  • 2942 Views
  • 3 replies
Hi,I am trying to install SG350 switch for the first time.I have Trunk coming from SG500 and is connected at port no. 24 on my new SG350 switch.On SG350 I wish to configure 2 VLANs exist on SG500 i.e. VLAN 17 & VLAN18VLAN17 has  ip address 192.168.17...
Prasad3 by Level 1
  • 535 Views
  • 3 replies
Dear Cisco, Currently on my Catalyst 2960 VLAN is assigned to a network port through SNMP using the following oid:  1.3.6.1.4.1.9.9.68.1.2.2.1.2. (IFACE)This allows me to reap the associated VLAN ID, and exploit it.I am looking for an OID allowing m...
lachenard by Level 1
  • 948 Views
  • 1 replies
Hello All, AP (1702i) is not discovering WLC while connecting on SG350-10P Gb PoE Managed Switch. But if I connect the same AP (1702i) on Cisco cat 3560cx switch it has no problem discovering WLC.  I am attaching the logs here for reference.What i am...
prashantk by Level 1
  • 731 Views
  • 1 replies
We have a network of 6 switches and are adding a 7th.  5 of the existing 6 are SG300 units and 1 is an old L3 Catalyst which is currently the gateway.  We tried to add another SG300-52P today but whenever we plug it in, the rest of the switches stop ...
StewJo by Level 1
  • 725 Views
  • 3 replies
Hi all, I'm about to buy SG220-26P switch. I have some other vendor access point which supports 802.3af mode A. Does SG220-26P support only mode A or only mode B, or it supports both? Most important question: will this other vendor access point work ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
