Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2540 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4045 Views
  • 1 replies
  • 16 Helpful votes
Hi,   I try to add a gateway through CLI on a SG350X-24  as per Configure the Internet Protocol (IP) Address Settings on a Switch through the Command Line Interface (CLI)   switchd1b11a#show ip interface IP Address I/F I/F Status Type Directed Prec ...
jwegge by Level 1
  • 10763 Views
  • 1 replies
Hello!We have SF220-48 switches and there are no "switchport protected" command:sw-u1(config)#interface fa1sw-u1(config-if)#switchport  access         VLAN unaware port  default-vlan   default vlan  dot1q-tunnel   802.1Q tunnel port  forbidden      f...
Hi All,   a banner message was created for a switch, when the following started to happen:   When i hit the"c" key on the keyboard in the CLI i get a SF300#% Ambiguous command message   Anyone know how to fix this? The person who created the banner u...
JVezinat by Level 1
  • 703 Views
  • 0 replies
Hello!I am trying to set up an ACL on our Cisco SG 300 switch. I want to create an ACL that enables hosts on our guest network to obtain IP addresses from a server on our "internal" network but they should not be able to reach any other resorses on t...
uitmorand by Level 1
  • 2730 Views
  • 5 replies
Hi,   I'm looking to upgrade the firmwire of my Cisco SF500 48P managed switch, however I'm not sure if I can upgrade from version 1.4.0.88 to 1.4.9.4 as the switch hasn't been updated in a long time? Can someone please help understand if it's OK to ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
