Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4130 Views
  • 1 replies
  • 16 Helpful votes
We have 2 offices with 6 switches ( 2 x sg350x (BB and CC )  and 1 xsg550x  (A / D) in each location tied via a EVC fiber on suppliers equipment..   A B B /-----/ C C Dthe 550x are for all servers via fiber 10G.the 350X are for users/printers/etc.rig...
frank123 by Level 1
  • 809 Views
  • 4 replies
We are seeing high CPU utilization on our 4500X running 03.06.05.E.152-2.E5.   Below is the output   cs01.a.colo.ri#show processes cpu sorted | ex 0.00Core 0: CPU utilization for five seconds: 35%; one minute: 11%;  five minutes: 6%Core 1: CPU utiliz...
Hi every body ,   Here is my problem: I have a SonicWall firewall - (192.168.2.1 / 21) Below I have a switch layer 3 (192.168.2.37), I'm setting some vlan: Vlan30 ip 192.168.30.1/24. I activate the routing: Ip routing roads: I tried several thi...
cmoinse by Level 1
  • 948 Views
  • 4 replies
hello I'm Harry I'm korean so I'm not good at speaking in English. Anyway I have some questions about sg300 I want to ping from valn1 to other vlan's without a router.As far as I'm concernd, normally switch can use a "ip routeing"commend but I can't ...
I got assigned to manage a rack that includes a Cisco SF300-08.   It was working fine.   I needed to login to it, but the previous admin did not leave the user/pass for the switch.   The defaults of "cisco/cisco" didn't work.   So I looked up how to ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
