Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
I have a problem with CBS350-24FP-4X, every time when I connect to the switch one of our panels PXM40.E it shows that there is overload over poe port. It shows as a counter of overloads and also in poe settings as a failure, but there is no informati...
aleand by Level 1
  • 628 Views
  • 4 replies
Hello,i try to backup the configuration of the SG250 Switch via http/https.I choose backup and http/http. It start to download a txt file but terminate then with network error.So i see the file running-config.txt with Network error and nothing is dow...
miso by Level 1
  • 381 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
