Small Business Switches
Helpful support links - emulator, video tutorials, support pages +
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
CoreyP319 by Cisco Employee
  • 1668 Views
  • 1 replies
  • 15 Helpful votes
SG200-50 Multicast Configuration
All, I am part of the CUCM TAC team and please bear with me as I do not handle much of the networking/switching aspect and really have no clue when it comes to the switches I am asking about. I've done some research and I can only find documentation ...
dgrup by Cisco Employee
  • 1223 Views
  • 2 replies
SG200-08 Inder-VLAN routing
I'm new to this forum and not too technical. I would like to connect a non-VLAN aware router to port 1 (or other port), create VLAN 2 and VLAN 3, connecting computers to them. Can the SG200-08 be configured to allow all devices on the VLANS to get to...
dgkurtz by Beginner
  • 613 Views
  • 0 replies
I could not access my switch interface on my static VLAN's in SG300-28P 28-Port Gigabit PoE Managed Switch
My Native/Default VLAN is 1. I have 2 other VLAN 20 and 200. From those VLAN I could not access my SG300-28P switch. Default VLAN 1 IP range 10.10.0.1 - 10.10.0.255 Static VLAN 20 IP range 10.10.1.1 - 10.10.1.255 2nd Static VLAN 200 IP range 1.0.0.1 ...
Inter Vlan routing on SG300
Hi all, I created 2 vlans in my switch Vlan10 192.168.1.1  Ports 1 to 12  (all untagged for this vlan) Ports 13 to 24 (excluded) Vlan 20 192.168.99.1 Ports 13 to 24 (all untagged for this vlan) Ports 13 to 24 (excluded) IPv4 Interface already configu...
diegog by Beginner
  • 688 Views
  • 2 replies
SF300 InterVlan + Router
Hello all, Just a quick question; I have a router with ip 192.168.1.248 connected on a L2 switch, and all pc's are using this as the gateway.From the L2 goes a cable to a SF300 L3 switch, on this switch i have three Vlan's; Vlan1 ------> 192.168.1....
GBonset05 by Beginner
  • 370 Views
  • 1 replies
Where is 1.0.0.86 firmware?
I did not know to update the boot software of my SRW2024 first, then update to 1.2.2b.I need to go back to the 1.0.0.86 firmware.Is it downloadable and will it work (ie work backwards and then do it properly)?  I know how to use hyperterminal and the...
peters1536 by Beginner
  • 1845 Views
  • 10 replies
Access RV042 v3 with http
I'm trying to upgrade a number of RV042s to v3.  I'm trying to update the firmware to the latest on those that already are in production and need to access them. I'm having a lot of trouble doing this. It appears that IE isn't suitable. On one situat...
fmarshall by Beginner
  • 371 Views
  • 0 replies
