Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
Не могу найти и обнаружить mib для коммутаторов Linksys SPS224G4 и Catalist С2900XL. Особенно интересует oid для диагностики кабеля на порту и сохранение конфигурации.Прошу оказать помощь в поиске данных oid или mib-base для коммутаторов Linksys SPS2...
aim by Level 1
  • 563 Views
  • 0 replies
Hello, I am using a SG500x in native stacking mode, utilizing the S1/S2-5G ports for stack. I use XG1/XG2 ports as 10Gb uplinks but i'm not able to use XG3/XG4 ports. How can I reconfigure XG3/XG4 as network ports to have 4 SFP port per switch availa...
HNS by Level 1
  • 3098 Views
  • 0 replies
This is my Task.switch port interface1 to 7 on different ip address must be releases.on d same switch.and 8th port only we use GUI method. and d port 9 & 10 only uplink.  I did 8th port only GUI method. want to know how to do 1 to 7 port release a di...
pharan.b by Level 1
  • 829 Views
  • 2 replies
Hi Folks, I have an SMB customer that has their voice and data separated behind two firewalls that then connect into their ISP.  They've been having VoIP issues with dead air inbound calls and I suspect the issue is with their outbound traffic cap at...
BillN by Level 1
  • 719 Views
  • 0 replies
Is there an alternative way to achieve the same behavior on an SG300 that the "logging synchronous" command typically achieves on other switches? The only option I see under logging in line mode is to turn it off. This is what I'm assuming "no loggin...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
