Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2590 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4116 Views
  • 1 replies
  • 16 Helpful votes
When connecting to the Console port and power cycling the switch, this is what I see: Image Loader 1.0.1 Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix Diagnostic 1.0.1 And that`s all, the next boot does not go.
crayz0001 by Level 1
  • 502 Views
  • 2 replies
I find a 4506 with x4515 in my storehouse.And I boot it success in my first timer.I want to clean all configuration.So I set confreg 0x2142 and reset in rommon.It reboot normally.But password  still there.5min later ,it reboot automatically.and I can...
x-key by Level 1
  • 656 Views
  • 6 replies
Hola, I've 3 switch units of the same model, 2 of them presents the same issue. The PoE devices I plugged in them aren't powered. Checking the switches via CLI I could see this: ------------------------------------------------------------------------...
Hopefully someone on here may have some insight on this.  I was given a SG200 26P switch.  I plug it in and the system light just blinks at me.  Now I know that this means it's using it's default IP address but none of the ports light up or will oper...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
