Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2589 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4106 Views
  • 1 replies
  • 16 Helpful votes
Hello, someone who help me? I bought a cisco SF302-08PP. I want to make network system as below image with L3 Switch(SF302-80PP) and L2 Switch(I have one). 1. Vlan 20 for controlling Lighting - 192.168.2.0 / 24 2. Vlan 30 for controlling Video    -...
Resolved! SG300 ACLs
Hi, I have two questions: - Can the SG200-50 do access lists? I've seen documents showing how to create ACLs for SG200/300, but it seems to me that mine can't because the option is not there. - I have 3 VLANs, one for data, one for cameras and one fo...
Hi guys, I have a Cisco 3560E directly connected to 192.168.5.0/24, and its only routing configuration is a default route to 192.168.30.202 SW1DC1#sh ip int briefInterface IP-Address OK? Method Status ProtocolVlan1 unassigned YES NVRAM administrativ...
PiEich by Level 1
  • 455 Views
  • 1 replies
Hi there, I am trying to upgrade the firmware on a Cisco SG200-50 switch. I was able to setup a TFTP server and get the boot code updated to version 1.3.5.06. When I try and update the firmware to the latest version (1.4.7.06) I am getting an "illeg...
HI I have 3 different customers all with the SG220poe50, firmware updated, they are running both voice and data through the switch on different vlans.  They have polycommVVX410 IP phones connected with the PC's then connecting via the phone.  The iss...
gary by Level 1
  • 365 Views
  • 0 replies
hey hi Good Evening, I have Sg 300 with 48 ports , and I am facing problem with Linux machines.. Do you have any idea about Smart Port Managment??? In my scenario i have 2 vlans 10 & 20. Also i have External DHCP server on vlan 10 . Now my problem is...
helpdesk by Level 1
  • 577 Views
  • 5 replies
Resolved! Cisco core
Hi, Can anyone please suggest me which model POE core switch best for small business with 15 vlan. I want to replace my existing nortel ethernet routing switch 8006. Please advice me the best. Thanks & Regards Raja
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
