Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
My sg300-28 28 port gigabit managed switch SW version    1.3.0.62Boot version    1.1.0.6 Like to upgrade higher versions 1.3.5. can i update the boot ver and fw version directly to 1.3.5., Also the time taken to reboot the switch.
sushindms by Level 1
  • 585 Views
  • 0 replies
Hi! I use the SG300 in Layer 3 mode so it routes between VLANs. I have multiple VLANs and want to isolate some of them. E.g. I have VLAN 10 which is 192.168.0.x Therefore I create an ACL and an ACE which shall allow only traffic from the same VLAN, s...
Anguel by Level 1
  • 703 Views
  • 0 replies
All, I am part of the CUCM TAC team and please bear with me as I do not handle much of the networking/switching aspect and really have no clue when it comes to the switches I am asking about. I've done some research and I can only find documentation ...
dgrup by Cisco Employee
  • 1423 Views
  • 2 replies
I'm new to this forum and not too technical. I would like to connect a non-VLAN aware router to port 1 (or other port), create VLAN 2 and VLAN 3, connecting computers to them. Can the SG200-08 be configured to allow all devices on the VLANS to get to...
dgkurtz by Level 1
  • 659 Views
  • 0 replies
My Native/Default VLAN is 1. I have 2 other VLAN 20 and 200. From those VLAN I could not access my SG300-28P switch. Default VLAN 1 IP range 10.10.0.1 - 10.10.0.255 Static VLAN 20 IP range 10.10.1.1 - 10.10.1.255 2nd Static VLAN 200 IP range 1.0.0.1 ...
Hi all, I created 2 vlans in my switch Vlan10 192.168.1.1  Ports 1 to 12  (all untagged for this vlan) Ports 13 to 24 (excluded) Vlan 20 192.168.99.1 Ports 13 to 24 (all untagged for this vlan) Ports 13 to 24 (excluded) IPv4 Interface already configu...
diegog by Level 1
  • 829 Views
  • 2 replies
Hello all, Just a quick question; I have a router with ip 192.168.1.248 connected on a L2 switch, and all pc's are using this as the gateway.From the L2 goes a cable to a SF300 L3 switch, on this switch i have three Vlan's; Vlan1 ------> 192.168.1....
GBonset05 by Level 1
  • 422 Views
  • 1 replies
I did not know to update the boot software of my SRW2024 first, then update to 1.2.2b.I need to go back to the 1.0.0.86 firmware.Is it downloadable and will it work (ie work backwards and then do it properly)?  I know how to use hyperterminal and the...
peters1536 by Level 1
  • 2160 Views
  • 10 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
