Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4130 Views
  • 1 replies
  • 16 Helpful votes
hi, i recommended a Cisco switch for my workplace because i learnt it was the best. they finally brought in SF 100-24 (small business) switch. but the problem is that i cant seem to configure and work with it at all. when i connect the computers thro...
kivoo4all by Level 1
  • 376 Views
  • 1 replies
Hello, So, I just got a SF300 switch for our small business. I am trying to configure it but i am a little confused. I have set the switch to layer 3 mode and accessed it through the CLI. I have created a new VLAN and assigned it all 24 Fa ports, I ...
Hi All, I've am not that advance level user of Cisco WLC but I have recently deployed (Dynamic VLAN) wired network security with cisco switches. The same I need to configure with Cisco WLC 2504 using the existing VLANs created in my network.  Scenar...
Hi,I have upgraded my SG200-08 switches from firmware version 1.0.5.1 to version 1.0.6.2. Since that new firmware is active, the network-printing from my Macbooks and iMacs is not working anymore. They all have TCP/IP connected network printers (not ...
RMBaltzer by Level 1
  • 29046 Views
  • 106 replies
Hola¡ Estoy configurando un SG500 y no consigo que los equipos de las diferentes subredes hagan ping al router, por lo tanto no tienen internet. Pego la configuracion a ver si me podeis echar una mano, muchas gracias¡¡¡¡¡ config-file-headerSG500v1...
josueruiz by Level 1
  • 396 Views
  • 0 replies
Have a question regarding the configuration of an SMB SG500-28P switch which we set up to be stacked with 4 other switches (all are SMB SG50028P). We preconfigured the switch before going and installing at the customer's site. When onsite we found it...
bcodeus by Level 1
  • 394 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
