Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
Hello, I have an SG 300 configured with 3 VLANs (in L3 mode) and my router is connected with the switch. I can not access internet from my VLANs except VLAN 1 with following IP assignments. PLEASE HELP. 1) - Router IP - 192.168.1.1    - Router LAN ...
Hi, I have two Cisco SG300 28P switches and one SF300 24P Switch. One of the SG300 Switches acts as a core switch (Core) The other two are (SG300-2) and SF300-1 and both are connected to the core switch. SG300-2 GE25 Links to port GE26 on the Core...
has123456 by Level 1
  • 659 Views
  • 1 replies
Hello I need to resolve a situation. I´m connecting a Switch Cisco Small Business SG200-50 with a Juniper SRX100, I can to access to switch cisco without restrictions, but the Juniper is owned from a provider, they give me the the connection to inter...
We have 2(two) SG300-28 switches. We have several VLANS that need to be truked between switch A and switch B 1. We are able to create 1 TRUNK port  that includs vlan 2,3,4 and it works fine between switch A and B.  We are now trying to create a 2nd T...
soupensu by Level 1
  • 804 Views
  • 1 replies
Hello, I'm pretty new to networking and managed to get hold of an SG200 and some other hardware. The rest appears to be working perfectly, however the SG200-18 seems to reboot every 12 seconds. The power light flashes continually (I assume normal f...
Hai team,                 My name is arun . I have one issue. Please help me using your valuable advice. I have one Scenario . We have two cisco switches sg 300 and two firewall Sophos UTM 230. One fire wall is master and other is slave for high ava...
ARUN.A by Level 1
  • 1189 Views
  • 7 replies
Hi All, Have you ever seen below message on SG500 switch before ? Jul 12 04:21:18 atviesw01 1 2016-07-12T02:21:17Z atviesw01 SYSLOG - OSFATAL - %SYSLOG-F-OSFATAL: FATAL ERROR: GOAH: ABORT DATA exception ***** FATAL ERROR ***** SW Version : 1.4.5.02...
pokemon by Level 1
  • 1167 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
