Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
Resolved! inter vlan routing
Hello all, I hope i can explain this where it makes since.  I have a Cisco 3650 vlan1 - mgmt  (dont care about this one) vlan5 - 10.24.1.50 /25   Port 11 connects to end-equipment at 10.24.1.100   Port 13 connects to Cisco 9010 at 10.24.1.99 /25  - (...
Dear Concern,                I have buys 8 Switches of Cisco Small Business SRW248G4(SF300-48) from local market at Karachi, Pakistan. I just wana conform that its Orignal or Copy, New & refurbish, below are the serial number of switches :-   1- DNI1...
syed19871 by Level 1
  • 317 Views
  • 1 replies
  • 270 Views
  • 0 replies
Hi everyone Hoping for some clarification, searching hasn't revealed anything clearly defined.As titled, 3 SG500 switches in a stack (running in L3 mode), firmware info belowFirmware Version (Active Image): 1.3.5.58Firmware Version (Non-active): 1.2....
Hello everyone, I am facing a problem with the configuration of a VLAN betweeen two SG200-26 switches (Firmware Version: 1.4.1.3), hope someone can help to me. My setup is pretty simple: __________                     __________|          |      LAG2...
proximine1 by Level 1
  • 2657 Views
  • 13 replies
We have recently bought a two stack SG500 28 port switches.  Firstly I should mention that I am an experience cisco admin but only with enterprise class devices. I linked the two switches together in a stacking config as per the documentation.  I hav...
Hello Every one im writing today on this forum because I'm fed up of everyone telling me " you just need to configure this!" and its doesn't work... here is my problem: I have 20 IP CCTV camera on an install who are connected to different switches (1...
mssfrance by Level 1
  • 1034 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
