Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2540 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4045 Views
  • 1 replies
  • 16 Helpful votes
I have a SG300 switch in L3 mode. This is what I have right now: Switch boots into VLAN 1. I wanted to create a second VLAN 2, 10/24 subnet. 84.5.163.129 is the external router switch is connected to. The routing table: S 0.0.0.0/0 [1/1] via 84.5.16...
anilj0001 by Level 1
  • 293 Views
  • 1 replies
Hi,i was checking the datasheet of 500X series and got confused regarding the 10GE uplinks. how many 10GE ports can be used for uplink and which transceiver should be used for 10GE copper uplink? for example, SG500x-24 switch has 24GE ports and 4x10G...
I'm using a Cisco SG200-08 in my private home network running the latest firmware to date (1.0.8.3) and I'd like to know if there are any plans in adding support for IGMPv3 in the near future. As more and more ISP are offering IPTV services these day...
dseebald1 by Level 1
  • 446 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
