Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2603 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4135 Views
  • 1 replies
  • 16 Helpful votes
HiWe've had a hiccup yesterday.Is this something that we need to look at closer?Stack of 2x SG500XG-8F8T, redundant connections.ThanksMichel 1474812372015-Jun-30 20:52:28Informational%AAA-I-CONNECT: New https connection for user <user>, source <ip> d...
i have a sg500 connected to a sg300 using 802.3ad and LACP, and trunk several VLANs over the Port-Channel.  the LAGs are set in General mode.  i recently tried to turn up GVRP, so i could have the VLAN database replicated from one switch to the other...
HiI need to implement VLANS across 3 SF-300 switches. We need VLANS to go across the switches. That is we can assign 3 VLANS to the different switches and they would be seen across the 3 switches. The switches are linked through their Giga Ethernet p...
hello ,Since i 've bought it my sg300-10p V01 has always report me a lot of%HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11c6 dev_num 1 val 0x0) was detected: POE is Disabled untill Reset  errors,and take always a very long ...
Hello community,My switch model is: sg500-28-k9-g5 to be precise.I have 4 switches in stacking mode in my setup and I want to upgrade them to a higher level firmware.Is it recommended that I remove the switches from stacking and upgrade individual sw...
Hello. First post here. I am new (again) to Cisco products. In a former life I had a bunch of Catalyst 10/100 switches but it has been many years. In the meantime I have gotten out of the "hands on" management and was overseeing exclusively Dell Powe...
Hello everyone. My company has a SG 300 here and we have access to it through console port but when we try to access through SSH we came across this information: "Connection closed by server: Server reached maximum number of simultaneous connections"...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
