Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
Hi all, tried searching but am unable to find an answer specific to my issue.I'm testing some equipment at the moment, the basic setup is tester software on laptop connecting through the on-board ethernet NIC to our DUT. Some data needs to pass throu...
When I am trying to configure VLANS to have a specific IP address, once I set up the IP Address on just one of the VLANS, the entire switch stops functioning and I have to perform a hard reset on the switch. I am using the GUI interface on the switch...
rscotty by Level 1
  • 310 Views
  • 1 replies
I have two switch: L3 SG500 -52 (firmware 1.4.0.88) and L2 SGE2010(firmware 3.0.2.0) . I create 4 Vlan in all switches : 1 DefaultEnabledEnabled   2PCStaticEnabledEnabled   3SERVERSStaticEnabledEnabled   4PCSECRETStaticEnabledEnabled   5MFUStaticEnab...
cas000002 by Level 1
  • 787 Views
  • 1 replies
I have a SG200-26P which I would like to have three interfaces COMPLETELY segregated from the rest of our network.. I though by using VLANS I could do that.. but the three interfaces I included in the VLAN and still communicating with the rest of the...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
