Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2593 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4124 Views
  • 1 replies
  • 16 Helpful votes
Hello,I'm trying to setup following scenario which is working with no issue on netgear switches (like GS108) but I have not been able to get it to work on Cisco SG-200I did quite a bit of reading here on many post but nothing seems to work. Setup:P1 ...
marcin by Level 1
  • 13714 Views
  • 8 replies
Hi all,I have a question regarding firmware upgrading, we having 2 switches are:WS-C2960-24TT-L and WS-C2960-24PC-L I ping from local network to vlan management of switch/ host within a switch with TTL is around 1ms or higher, sometimes TTL is upto 1...
I've got an SG500-52 in L3 mode with IPV4 addresses configured on 2 VLANs (1 & 2).DHCP server is running on the switch, and only one pool is configured (for VLAN 2's subnet).While running a packet capture for testing out something with DHCP, I notice...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
