Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
I've got an SG500-52 in L3 mode with IPV4 addresses configured on 2 VLANs (1 & 2).DHCP server is running on the switch, and only one pool is configured (for VLAN 2's subnet).While running a packet capture for testing out something with DHCP, I notice...
Hello,I have a network with 3 Cisco SG500.1. SG500-282. SG500-523. SG500-28PThey are stacked with the S3/S4 ports with fiber in a ring.So all is working as expected, but when I add a device on switch 2 or 3, I lose connection to switch 1. Like if it ...
dloeliger by Level 1
  • 4442 Views
  • 6 replies
Hi, i recently did firmware upgrade in sf300 8port manged switch from version 1.0.0.7 to 1.3.0.62. Upgradation was cool and the device started booting with new image without any concern. One fine day i identified that interface VLAN configuration cha...
Please take a look at my rough drawing of how I would like my network to work:                        SG300-10       __________________________________________       | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |       |_|___|____________________________...
We have an SG200-26 and unfortunately one of it's ports is connected to it a dumb switch. Whenever this dumb switch is disconnected and reconnected multiple things happen.  1. Port security kicks in and Dynamically locks the port even though all port...
sammycbmi by Level 1
  • 3946 Views
  • 9 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
