Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
Hi,I'm a new user of SG 200-18 but surprised the telnet and snmp fault!Why SG 200-18 don't have a telnet service  to management?Is possible to place the telnet service on the next firmware?And the SNMP?Thanks,all regards,Nuno Martins
nmcmartins by Level 1
  • 12371 Views
  • 6 replies
I have problems with switch SG300-20. The switch is connected to a AVM FritzBox.Configured are fix and dynamic (DHCP) IP Areas (see attachment) in the FritzBox.Following issues occurs.The devices with dynamic IP's get not a valid IP-Address after res...
Currently I have SG300 with 3 ports in a LAG with LACP enable going to a second SG300.  Now I have been told that I should not use LACP connecting switches. Can anyone shed some light on this ??  If this is not recommended then how do I remove the LA...
mikecom68 by Level 1
  • 1556 Views
  • 3 replies
Hi, I've create 2 vlan in a cisco SG500X-24 and a DHCP server on vlan 2. I just want to dhcp server assign ip to devices on vlan 3. I've configured the vlan and dhcp server relay commands.ip dhcp relay address 192.168.1.11ip dhcp relay enableip dhcp ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
