Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4130 Views
  • 1 replies
  • 16 Helpful votes
Resolved! CBS350 capacity
Hello, I will setup a small network with 176 devices connected to the IP backbone. I want to use the CBS350 as an aggregation switch connected to 8 CBS220 switches in fiber 1G. Do you know if the CBS350 can handle 176 clients ? If yes, how many clien...
I am having issues resetting a SG250 back to factory settings. I hold the reset button for long enough, and the switch goes back to factory settings for 10 seconds, and i can ping its default IP address, but then suddenly it seems to go back to its c...
Paulsebas by Level 1
  • 452 Views
  • 1 replies
I have 2 SG500s that are running pretty old code and wanted to get them updated.  Both are running 1.3.7.18 firmware, but 1 is running 1.3.0.03 boot code and the other is running 1.2.0.12.  I know the expected boot code for firmware 1.3.7.18 is 1.3.7...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
