Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
I need to provide a RoHS Cert for a SG-300-20 for a pre-sales engagement.  The link on the website says for a SG-300-20 (SWR2016-K9-NA) but displays a cert for RoHS is identified for the -EU version but the associated document EU18337 shows model SG2...
bchaltra by Level 1
  • 841 Views
  • 2 replies
Hello, I had a very strange occurrence recently which I suspect has corrupted my Cisco SG500-28P switch.A couple days ago the power went out and the switch turned off, shortly after the power returned... but the switch did not power back on. I pulled...
Resolved! IOS upgrade issue
Hello,       I have cisco WS-C2960-24TC-L, I tried to upgrade the IOS from <c2960-lanbase-mz.122-53.SE2.bin > to <c2960-lanbasek9-mz.122-55.SE9.bin> , but it didn't work with new IOS, so I rolled back to the old one again, what may cause this problem...
Hi just looking for a little clarificationWe use a mix of SF300 SG300 Non PoE & PoE [including MP & MPP], we also have a couple of SG500s Non PoE & PoEWhat is the best practise for loading config files on these switches - and are the config files cro...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
