Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
Hi all,i've installed switch SF300 48 ports for IP phone environtment, i configured it as guide, if i attach ip phone it works normally,but when i plug laptop to switch port, it cannot connect to anywhere, then i tried to change native vlan for smart...
ahmed by Level 1
  • 1795 Views
  • 7 replies
we have several sf-300 series switches, 24 port, 10 and 8 ports with poe.  somehow with no rhyme or reason, the vlan setup on the switches is dropped or removed from the configuration whenever an ip phone is disconnected and the only one left is the ...
I have 3 SG500X in chain native stack, 2 SG500X-24 and y 1 SG500X-48: sw-stack#sh stackCurrent stack mode is  : nativeUnit Model Name     MAC Address       Software  Master   Unit No./     Status                                                       ...
Hello all,I am learning how to write ACLs, and one of the exercises is that I have to write an ACL to restrict PING, HTTP, FTP, and allow POP3 and SMTP between a pc and server.  Below is my ACL.  The thing that does not work is the POP3\SMTP access. ...
I have a problem.Here is some lines from config:default-vlan vlan 2interface vlan 1 no ipv6 dhcp client stateless !interface vlan 2 name Management ip address 10.0.4.103 255.255.252.0 no ip address dhcp ipv6 address autoconfig ipv6 dhcp client st...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
