Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
Hello,I have problem with simple VLAN:I change switch to layer 3 system mode.To port 1 I have connected router. I create 2 vlans:VLAN settings: vlan id 2    and vlan id  4I go to Port VLAN Membership and I join vlan to GE2 2T, GE3 2T, GE4 4T, GE5 4T ...
karol.r by Level 1
  • 562 Views
  • 0 replies
Hello,The company I work for has some Cisco hardware in the plant and, as our team has no expertise on configuring Cisco switches I hope you can help me and my team to get this problem solved. I will make a brief comment on what is going wrong here:I...
nataniel by Level 1
  • 1101 Views
  • 1 replies
                   I would like to connect a Sonicpoint to an installed Cisco SRW224G4P switch.  Sonicpoints support multiple SSIDs, each on a VLAN.  One VLAN is Corporate (20) another Guest (30).  Guest pointing outward to internet only via firewall...
Hello my name is chris and i have a slm2048 switch that my boss has forgot the password to and he need to me to get on to it's gui. I have tries to hold down the reset switch for at least 10 seconds and it will not reset to factory defaults. For some...
c-holland by Level 1
  • 3944 Views
  • 3 replies
We added a SLM2048 gigabit swtich to our office recently.  It works, devices connected to it are able to access the LAN and internet.  However, I can't access the web interface for some reason.  When I enter the default IP address (192.168.1.254) in ...
Kevin5678 by Level 1
  • 2013 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
