Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2587 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4103 Views
  • 1 replies
  • 16 Helpful votes
Hello All,Installing 2 SG300 switches (latest firmware) in a small network gave me the following challenge:How can I bind an IP ACL to a VLAN instead of a physical port?The situation:- 1 central SG300-20 in layer 3 incuding trunk to L2 SG300-10.- 1 r...
I have downloaded the new firmware for the SG500.   I see there are two files included in the download, a boot file (rfb) and regular firmware image (ros).   I have looked and haven't seen anything about the rfb files.   I know it is a boot file, but...
jdurrence by Level 1
  • 17468 Views
  • 2 replies
Hi all,is there a way to find out what kind of SFPs are in an SGE20x0 switch? Both on the GUI and on the LCLI I don't see this information. Thanks in advance, Karsten--  Don't stop after you've improved your network! Improve the world by lending mone...
HiAccording to it's datasheet and administration guide the RV320 support 16 VLANs. But the device emulator allows you to add four new VLANs while 3 is already set up, making a total of 7 VLAN's. Is the device emulator based on old firmware? Can anyon...
Hi all, I have bought a SF 302-08MP Switch, thinking that this works like a Switch 2960, ie, I want to configure VLANs and ports TRUNK.But when I connect via console shows me a series of menus that do not allow me to configure the ports to VLAN, or c...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
