Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
Resolved! SMB configuration
Hello I'm tying to validate this SMB configuration."Core"in stack configuration ring2 SG500 24 ports 1 SG500 48 ports3 SFP-H10GB-CU1M= for 5G stack5 MGBSX1 (uplink to access)1 copper uplink port (combo) link to CLC"Access"3 SG300 48 ports2 SG300 24 p...
Can't seem to get DHCP to function properly with my SF302-08 in the network path. Thesetup looks as follows:wall-jack                <->  Linksys 8 port switch                                                    <->  SF302-08                          ...
Hi,I wonder if the SG300 there is a "MIB" which allows for the cumulative traffic on all interfaces for a particular vlan.I know we have this information in Catalyst switches in the SMON MIB but I can not find the equivalent in the SG300Thanks
ultimeo74 by Level 1
  • 978 Views
  • 2 replies
HiI have 5 clusters in a data center running with VMware dv switch and standard switches .All are E.P licences. I am planning to create nexus 1000v switch and migrate all of the cluster networks to Nexus 1000v switch . since Nexus 1000v is most advan...
10june861 by Level 1
  • 644 Views
  • 1 replies
Hi,I have two NAS. Each one from a different manufacturer, QNAP and Synology.The two NAS support LACP IEEE802.3ad but in this way QNAP loses 40% of the packets and Synology not work.With a Cisco Calatyst 3750 both NAS I work well. Do I have to do som...
I received a new SG300-28 with FW 1.2.9.44 and Boot version 1.1.0.6.  A couple of weeks ago I had an SG500-28 and I udated that to Sx500_FW_1.3.0.62 ros and Sx500_BOOT_1.3.0.03 rfb.  I checked for the current version for the SG300-28 and I downloaded...
viningele by Level 3
  • 4987 Views
  • 3 replies
SG300-28.  If I config int gi20 to be switchport mode access and then set the access vlan to 100 but I then set the smartport role to desktop it set the $native vlan of 1 so are incoming untagged headers tagged as 100 or 1?  I figure I need to either...
  • 1831 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
