Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2590 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4119 Views
  • 1 replies
  • 16 Helpful votes
Hi everyone, my switch cisco small business SG200-26G  in modality link aggregation LACP the Wake On Line doesn't work !! (WOL work only in link aggregation non LACP..) I already upgrade the latest firmware but not resolved.. Do you know how to point...
Hi,I have to configure multiple vlans served with a unique DCHP server . As first step, I just will The DHCP server to serve 2 vlans. The following is the hardware and configuration that I implemented :Router (RV016 10/100 16-Port VPN Router) as gate...
Hello,We have a Cisco SF 300-08 here at work that cannot be used. The system lights are green and flashing. I looked into the manual and pressed the reset button for more than 10 seconds for a factory reset. The port lights lit up momentarily and the...
Old_Snake by Level 1
  • 2528 Views
  • 2 replies
I just recently purchased an SG300 10 port switch. After reading through many of the threads here, I was finally able to get the different VLANs to route properly. However, I'm having a unique issue that I'm not sure if it's related to the switch or ...
dapolloxp by Level 1
  • 4084 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
