Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2599 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4127 Views
  • 1 replies
  • 16 Helpful votes
Hi,Currently, I've got an issue with a Cisco SF 300-48P.The ports are configured with the auto smartport configuration.When I connect an IP phone + desktop, the port security feature is enable every time.I don't understand why, because the maximum ho...
Hello,I have an issue with using IGMP snooping on SPS224G4.After some period of using I get such message in log:%BRG_IGMP-W-TABLE_OVERFLOW: IGMP group table overflowAfter a little time after event the switch became uncontrollable.Normal functionality...
vlutsenko by Level 1
  • 993 Views
  • 0 replies
Hi All,I'm doing some tesing in SFE2000P linksys switch about the TACACS authentication. I have configured the switch accodringly to point my ACS server with key string. Now, I'm able to login into the switch with TACACS account in HTTP/HTTPS only an...
PFG TAC by Level 1
  • 1425 Views
  • 6 replies
I am attempting to set up a vlan using 2 SLM2024's and a Cisco  asa 5505.  I have performed this operation more times than I can count,  though never with the 2024, and thought I could do it in my sleep.  I am  now baffled.  The firewall and VLAN con...
Guys, I'm working on a home automation project with 3 SGE 2000P's. I think there are some configuration issues that's slowing down the network BIGTIME. I have all 3 in standalone mode, on static IP's, and every port with autonegotiation DISABLED runn...
jholt by Level 1
  • 1262 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
