Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
Hi,I am planning to purchase a 48 port 10/100 switch and 2 Gigabit Uplink ports. Just want to ask what is the computation for Link Aggregation? For me to be able to know if I will consume the Aggregated Link of the two Uplink Ports. Just curious on t...
Our SGE2010 switch is accepting connections using SSLv2 (according to the PCI compatibility scanner)Is there a way to prevent it from accepting / responding to connections using this version of SSL but still allowing connections using SSLv3 or TLS?If...
Hi all! I have a problem with switches SPS208G2. They're conected with SFP module after Linksys SPS224G4 and another swithes. After reboot switches which are conected with SPS208G2 don't see link. However previous switches phisical link status is up ...
I'm trying to setup an ACL on my SG300-20 to enable FTP and a few other protocols to a server, but I'm running data that returns on different ports (ie active FTP).Below is a sample:-------------------------------------------Extended IP access list P...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
