Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
We are using a SD2005 unmanaged switch and the requirement has changed to require DoD Information Assurance to be applied.I have not found any user's guide to allow any configuration of the SD 2005.Is configuration possible on an unmanaged switch and...
KratosDEI by Level 1
  • 884 Views
  • 1 replies
Greetings.I have an SG-300-IP Gig POE switch installed and connected to a Cisco 1921 router - in turn conected to DSL.I have the router running DHCP.  Hosts can connect - get and IP and relevant DNS servers - can ping Internetby name and number - but...
iholdings by Level 1
  • 1048 Views
  • 1 replies
Hi Guys,I am using around 5 sg300's with a lot of Crestron AV kit / touchscreens. About once every couple of months the touchscreens all stop responding. We have found that a reboot of the Cisco switch attached to the touchscreens brings everything b...
phcjpp123 by Level 1
  • 856 Views
  • 2 replies
For having 3 settopboxes for iptv I have setup vlan 3 for iptv.IGMP snooping is enabled for vlan 3 with the default settings and port 5 (incoming iptv) is enabled as IGMP Mrouter.In the multicast forwarding table vlan 3 is set to filter unregistered....
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
