Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2589 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4106 Views
  • 1 replies
  • 16 Helpful votes
We sold an ESW 540 switch to a 3COM customer that is replacing old equipment. This replacement will be on different faces so we have to interconnect some 3COM switches to the Cisco equipment. We are installing rigth now and this two situations:Virtua...
jgarcia by Level 1
  • 1808 Views
  • 5 replies
I'm completely new to VLANs, and I have a client who has a SG300-20 switch. This location is basically a shared office space with individual offices inside a large building. Each office has network ports that lead back to a patch panel, which then is...
Does anyone know if there are specific port settings required to get a Cisco switch to talk to a 3com switch? I have a 3com 4500 switch that will uplink to a Netgear L3 switch fine with the exact same settings as the Cisco SG300-52 i have but with th...
MRP_Chris by Level 1
  • 1428 Views
  • 5 replies
Originally, my  client had SG300-28 (purchased by mistake) instead of SG300-28p. I had  configured SG300-28 from CLI and CCA (CCA is a requirement for the Small  Business Pro department to support the voice solution). I then tftp'ed  the config to my...
Resolved! SG200-08
Hi,I bought an SG200-08 switch in december. This one has refused to boot with an orange led port 1 on. The second one I received for the replacement refused to start too. The led system is green flashing all the time and the switch refused to start. ...
Hi,Fromhttp://www.cisco.com/assets/sol/sb/Nikola_GUI/SG_300-28P_v1_1/config/home.htmIP Configuration > Management and IP Interfaces > IPv6 TunnelI would like to know how i can use this?.If i enable isatap on switch and a successful connection with is...
cisco4239 by Level 1
  • 722 Views
  • 0 replies
Why does the sx300 series only displays ping and traceroute results in 20ms intervals (see below)? The example in the CLI manual shows "regular" results. These 20ms intervals are not helpful for troubleshooting.  This is version 1.1.0.73 on an sf300-...
cavan1975 by Level 1
  • 2075 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
