Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2591 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4124 Views
  • 1 replies
  • 16 Helpful votes
Hello Team,I have a Cisco SG350 10P K9 Managed POE Switch in this switch am pluging five Access point at a time then Three access point is working and rest two access point not working. When am access my switch through GUI then showing the error FAUL...
ramkishor by Level 1
  • 1118 Views
  • 5 replies
In An SG350-28P, using the latest firmware, 2.3.5.63, I find no way to set the static IP on an SG350-28P.  IP Configuration -> IPv4 Management and Interface -> IPv4 Interface -> select VLAN 1 -> Edit -> Static is hard coded and cannot be changed.   T...
Terabyte by Level 1
  • 45513 Views
  • 21 replies
  • 5 Helpful votes
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
