Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2602 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4133 Views
  • 1 replies
  • 16 Helpful votes
I have a problem using 802.1x authenication on my customers SLM2008-switch. I see thet the switch try to authenticate to the Radius Server (Microsoft 2008), but the Radius Server do not accept the Radius request. I can see the following error-message...
helgee by Level 1
  • 642 Views
  • 0 replies
I need create vlans in Cisco SF 300-24 Switch.Ports 1 to 6 are available for other ports (from 7 to 24).For examples: port 7 is available for ports from 1 to 6 but is not available for ports from 8 to 24,port 8 is available for ports from 1 to 6 but...
dominik15 by Level 1
  • 57129 Views
  • 7 replies
Does anyone have some tips and trick on how to configure and sg300 for intervlan routing.I already have the switch set up for layer 3I already set up multiple vlans and each vlan has a ip interface setup with the desired subnetI see the local routes ...
pfontana by Level 1
  • 1861 Views
  • 6 replies
I am using the Cisco SF302 switches as a connection to some wireless devices that will link two buildings together.In this configuration: Cisco 3570 in building 1 >> Cisco SF302 >> building 1 wireless bridge >> building 2 wireless bridge >> Cisco SF3...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
