Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2600 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
Hello,I got a used Cisco SG200-08P switch missing its power supply. To check if the switch is still in working conditions, I tried to power it up with a PoE injector connected to port 1 without success. I was wondering if this is conclusive evidence ...
mdett by Level 1
  • 945 Views
  • 4 replies
Hello,I'm working on cisco SG300 switch, after collecting traffic data (received octets) from it using snmpget I got this graph: 1.The drop of data from the maximum value may be due to drop in user activities, is there any other reason for this rapid...
Hello,BPDU Guard feature is not supported in version 1.3.0 of Cisco SW (SG200-50 ), I need to know please if it is supported in the lastest versions ? 1.4 for example ?If so, which version is the most recommended ?Switching, WANSwitching, WAThank you...
Dear All, Hope u are doing well. I have SG250 26POE, daily when i tried to take Telnet/SSH session it denied my access and also the "SH IP ARP" also not resolved. Further i m getting MAC address against that connected port and also getting SW details...
Hi,QoS Egress per shaping configuration at Cisco SF300/24 here Four (4) Queue Egress shaping 1,2,3,4 but why this Queue 1,2,3,4 and where to use?I am using each per port 6Mbps and Queue Egress shaping 1,2,3,4 use 6Mbps, 5Mbps,3Mbps, 2Mbps, it's work ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
