Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2540 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4045 Views
  • 1 replies
  • 16 Helpful votes
Hi, In our Catalyst 2960 switches, we used the command below to auto backup config to our TFTP server. archive log config logging enable hidekeys path tftp://192.168.1.100/Switches/ISO/$h- write-memory time-period 10080I think this is not the same ca...
DariusPH by Level 1
  • 919 Views
  • 1 replies
Hello Everyone, We have a number of Cisco SG550X-24-K9 switches, they are used as ToR switches for the Data Center (physical servers). I enabled jumbo frame on all switches, but I am unable to set the MTU of the interfaces, neither from the UI nor fr...
Hello,   I'm simply trying to create an LACP link between a SG500 and SG500X. The problem is on the SG500X which is the new switch I'm setting up - there are already other switches using the SG500 with an LACP link just fine, just this SG500X is givi...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
