11-14-2013 04:42 PM
Hello,everyone
I am dealing with SG300-10 switch. I am trying to assign a ip address for a new VLAN ID. But I can't ping it after I finished.
First, I added a new VLAN ID(100)
Then I assigned a port to that vlan
Finally, I added a ip address for that vlan id
After that, I tried to ping 192.168.10.24, but it was not working.
Is there anything wrong I did?
Solved! Go to Solution.
11-15-2013 09:35 AM
Hi Jiahing, you're giving too many omissions. Everything about the VLAN's, IP addresses, gateways, physical connection and firewalls matter.
This is how to configure everything to get basic connectivity.
Host A connects to port 1 on VLAN 1.
Host A IP address will be 192.168.1.10 with mask 255.255.255.0 with gateway 192.168.1.254
Host B connects to port 2 on VLAN 200
Host B IP address will be 192.168.2.10 with mask 255.255.255.0 with gateway 192.168.2.254
The switch configuration would be as follow-
config t
vlan database
vlan 200
int vlan 1
ip address 192.168.1.254 /24
int vlan 200
ip address 192.168.2.254 /24
int gi0/2
switchport trunk native vlan 200
-Tom
Please mark answered for helpful posts
11-14-2013 05:41 PM
Hi Jiang, if there is no active connection in VLAN 100 it will not work. Conversely, if no active connection in VLAN 1 it also will not work.
-Tom
11-14-2013 05:48 PM
Hi Tom. I am sure there is an active connection in VLAN 100.
11-14-2013 05:54 PM
Alright, 2 scenarios.
Scenario 1-
Host A is connecting to the switch on VLAN 1 with IP address 192.168.1.10 255.255.255.0 with gateway 192.168.1.254. While there is an active connection on VLAN 100, Host A should be able to pnig 192.168.1.254 AND 192.168.10.254
Scenario 2-
Hostt B is connecting to the swith on VLAN 100 with IP address 192.168.10.10 255.255.255.0 with gateway 192.168.10.254. Host B should be able to ping the VLAN 100 SVI at 192.168.10.254.
-Tom
11-15-2013 08:53 AM
I am not sure what's wrong with it. I assign port1 to vlan 1 with ip address 192.168.1.254. Then I connect laptop A to port1. I also assign port2 to vlan 200 with ip address 192.168.2.254. Also I connect laptop B to port2. I am in layer3 mode now.
Port1 is in Trunk mode and port 2 is in General mode. I can ping 192.168.1.254 on laptop A. But I can't ping 192.168.2.254 on laptop B.
11-15-2013 09:35 AM
config t
vlan database
vlan 200
int vlan 1
int vlan 200
int gi0/2
-Tom
11-15-2013 12:15 PM
I see!!! Thanks Tom.
