CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
237
cannot load ios image in rommon mode cisco catalyst 9200
dear all,
I have done a factory reset on my cisco catalyst 9200L-24P with the command: factory-reset all
Now I want to load a ios from a usb stick, but it is not loading. the switch is not reading the usb stick and is stuck at the rommon mode.
Copying trough xmodem didn't helped also. Getting the following error:
switch: copy xmodem: flash:cat9k_lite_iosxe.16.12.01.SPA.bin
Unsupported destination device/filesystem.
please help!
2 ACCEPTED SOLUTIONS
VIP Advisor
Re: cannot load ios image in rommon mode cisco catalyst 9200
Hall of Fame Community Legend
"xmodem"?  Wow.  That's an archaic command that is no longer relevant.
Try the command "copy usbflash0:cat9k_lite_iosxe.16.12.01.SPA.bin flash:".
3 REPLIES 3
VIP Advisor
thank u sir, the IOS is loaded.
I have used the following command.
boot tftp://TFTPSERVER_ADDR/cat9k_lite_iosxe.16.09.02.SPA.bin
But now I cannot login in the web interface with the default credentials ( username cisco or webui and password SERIAL NR ).
