CANNOT PING
I can not ping from PCA to S1 vlan.
This is the topology:Screenshot_20190928-194937_Packet Tracer Mobile.jpg
Thank you;
luis_cordova
Hi @AbdulmajeedAlmaweri4471
Make sure all devices have the gateway address configured, including the switch:
PCB
IP: 192.168.100.13
Mask: 255.255.255.224
Gateway: 192.168.100.1
S1
S1(config)# interface vlan 1
S1(config-if)# ip address 192.168.100.10 255.255.255.224
S1(config-if)# no shutdown
S1(config-if)# exit
S1(config)# ip default-gateway 192.168.100.1
PCA
IP: 192.168.100.33
Mask: 255.255.255.252
Gateway: 192.168.100.34
Remember to mark the correct answers as a solution, because that helps other users with similar questions
balaji.bandi
You required static routing required both ends to reach each other. traceroute command tell you where it is losing the routing.
can you post-show ip route 2960 and 1941
BB
luis_cordova
PCB
IP: 192.168.100.13
S1
S1(config-if)# exit
PCA
IP: 192.168.100.33
