Catalyst 3750- X Series
adrian.chin
I have trouble to access the switch on 2nd password whereby i want to proceed with "en" to enable  but there's messages shows "B50-C3750>en
                                         % No password set"
Are there any options to solve this issue instead of resetting the switch to factory default?
Need your kind expert assist.
many thanks.
eric.ahernandez
Unless you have a privilege 15 username you can use to login directly to privileged mode so you can configure the enable password, you will have to do a password recovery:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swtrbl.html#wp1021182
