CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
23267
Highlighted
Beginner
Catalyst and SG300-52 - Native VLAN mismatch detected
Dear all,
I have 3 switch:
     1 core is C3750x-24 ports
     1 access is C2960s-24 ports
     1 access is SG300-52 ports
I have 1 question about NATIVE VLAN configuaration on trunk port between Catalyst 3750x-24 and SG300-52:
I config Native VLAN 999 in all of switch but only SG300 say this message:
03-May-2013 03:53:59 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch det
ected on interface gi52.
03-May-2013 03:54:01 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected
on interface gi51.
How to fix it?
Below is my configuration in Port-Channel in all of switch:
The configuaration of Port-Channel 1 (Gi1/0/11-12) in C3750x, this is connect to C2960s
Core3750x#show interfaces po1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 999 (Trap)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 10,20,30,40,50,60,70,80,99
Pruning VLANs Enabled: 2-1001
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Core3750x#
The configuaration of Port-Channel 2 (Gi1/0/13-14) in C3750x, this is connect to SG300
Core3750x#show interfaces po2 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
Core3750x#
The configuaration of Port-Channel 1 (Gi1/0/47-48) in C2960s, this connect to C3750x
C2960s#show interfaces po1 switchport
Switchport: Enabled
Negotiation of Trunking: On
Voice VLAN: none
Protected: false
C2960s#
The configuaration of Port-Channel 2 (Gi51-52) in SG300, this connect to C3750x
SG300#show interfaces switchport po2
Port : Po2
Port Mode: Trunk
Gvrp Status: enabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 999
Port is member in:
Vlan               Name               Egress rule Port Membership Type
10                 10                  Tagged           Static
20                 20                  Tagged           Static
30                 30                  Tagged           Static
40                 40                  Tagged           Static
50                 50                  Tagged           Static
60                 60                  Tagged           Static
70                 70                  Tagged           Static
80                 80                  Tagged           Static
99                 99                  Tagged           Static
999                999                 Untagged          Static
Forbidden VLANS:
Vlan               Name
Classification rules:
Mac based VLANs:
  Group ID   Vlan ID
SG300#
Then CDP message on SG300 is:
SG300#03-May-2013 03:53:59 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch det
on interface gi51.
Best regards,
Truoc
Everyone's tags (2)
12 REPLIES 12
Highlighted
Advocate
Hi Truoc, can you provide the show run for the ports of the catalysts? Native vlan mismatch means the untagged members don't match up and the Catalyst behaves differently than the sx300.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Highlighted
Beginner
Dear Mr. Tom,
Thank you for your answer!
This is the running ports:
This PO1 connect to C2960s
interface Port-channel1
description Connect To MO01
switchport trunk native vlan 999
switchport trunk allowed vlan 10,20,30,40,50,60,70,80,99
switchport mode trunk
switchport nonegotiate
storm-control broadcast level 10.00
This PO2 connect to SG300
interface Port-channel2
description Connect To MO02
This is 2 ports connect to C2960s
interface GigabitEthernet1/0/11
channel-group 1 mode active
interface GigabitEthernet1/0/12
This is 2 ports connect to SG300
interface GigabitEthernet1/0/13
channel-group 2 mode active
interface GigabitEthernet1/0/14
Best regards,
Truoc
Highlighted
Advocate
Hi Truoc, can you show the cdp neighbor detail from each switch (catalyst and smb)?
-Tom
Highlighted
Beginner
Re: Catalyst and SG300-52 - Native VLAN mismatch detected
Dear Mr. Tom,
Actually I have 1 Catalyst 3750x-24, 1 Catalyst 2960s-48, 4 Cisco SG300-52 and some Linksys Cisco SRW2024.
Then I show 2 CDP neighbor on 2 swith to you, can you view this detail and help me how to fix my issue.
I saw the detail in Catalyst say Native VLAN in my SG300 is #1 but I already switch port-channel in SW300 to Native VLAN999!
Then now I can't switch manual port member channel to Native VLAN 999, the message as below:
MO02(config)#int gi49
MO02(config-if)#switchport trunk native vlan 999
Port gi49 belongs to a port-channel
Thank you so much!
Truoc.
Here is detail of CDP:
Catalyst C3750x
Core3750x#show cdp neighbors detail
Device ID: 70105c122f75
Entry address(es):
  IP address: 172.16.16.19
Platform: Cisco SG300-52 (PID:SRW2048-K9)-VSD,  Capabilities: Switch IGMP
Interface: GigabitEthernet1/0/22,  Port ID (outgoing port): gi50
Holdtime : 170 sec
Version :
1.3.0.62
advertisement version: 2
Native VLAN: 1
Duplex: full
Power Available TLV:
    Power request id: 0, Power management id: 19500, Power available: 0, Power m
anagement level: -1
Management address(es):
Entry address(es):
Interface: GigabitEthernet1/0/21,  Port ID (outgoing port): gi49
Holdtime : 170 sec
Version :
1.3.0.62
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 8397, Power available: 0, Power ma
nagement level: -1
Device ID: C2960s
Entry address(es):
  IP address: 172.16.16.11
Platform: cisco WS-C2960S-48TS-L,  Capabilities: Switch IGMP
Interface: GigabitEthernet1/0/11,  Port ID (outgoing port): GigabitEthernet1/0/4
8
Holdtime : 129 sec
Version :
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE4,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 26-Jun-13 02:59 by prod_rel_team
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=0AA7278
0000000000102270170105CA7278070105CA72780000000
VTP Management Domain: 'tmi.com'
Native VLAN: 999
Duplex: full
    Power request id: 0, Power management id: 1, Power available: 0, Power manag
ement level: -1
Device ID: C2960s
Entry address(es):
Interface: GigabitEthernet1/0/12,  Port ID (outgoing port): GigabitEthernet1/0/4
7
Holdtime : 129 sec
Version :
Native VLAN: 999
Duplex: full
ement level: -1
Device ID: 54781ae8dcf3
Entry address(es):
  IP address: 172.16.16.12
Interface: GigabitEthernet1/0/13,  Port ID (outgoing port): gi49
Holdtime : 122 sec
Version :
1.3.0.62
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 14202, Power available: 0, Power m
anagement level: -1
Entry address(es):
Interface: GigabitEthernet1/0/14,  Port ID (outgoing port): gi50
Holdtime : 122 sec
Version :
1.3.0.62
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 531, Power available: 0, Power man
agement level: -1
Device ID: 70105c121f1a
Entry address(es):
  IP address: 172.16.16.15
Interface: GigabitEthernet1/0/18,  Port ID (outgoing port): gi51
Holdtime : 179 sec
Version :
1.3.0.62
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 32174, Power available: 0, Power m
anagement level: -1
Entry address(es):
Interface: GigabitEthernet1/0/17,  Port ID (outgoing port): gi52
Holdtime : 179 sec
Version :
1.3.0.62
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 14080, Power available: 0, Power m
anagement level: -1
Device ID: 70105c1218af
Entry address(es):
  IP address: 172.16.16.17
Interface: GigabitEthernet1/0/20,  Port ID (outgoing port): gi50
Holdtime : 127 sec
Version :
1.2.9.44
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 8954, Power available: 0, Power ma
nagement level: -1
Entry address(es):
Interface: GigabitEthernet1/0/19,  Port ID (outgoing port): gi49
Holdtime : 127 sec
Version :
1.2.9.44
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 22873, Power available: 0, Power m
anagement level: -1
Core3750x#
Cisco SG300:
MO02#show cdp neighbors detail
Device-ID: Core3750x
Advertisement version: 2
Platform: cisco WS-C3750X-24
Capabilities: Router Switch IGMP
Interface: gi49, Port ID (outgoing port): GigabitEthernet1/0/13
Holdtime: 138
Version: Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.
0(2)SE4, RELEASE SOFTWARE (fc1)
Cop
Duplex: full
Native VLAN: 999
SysObjectID: 0.0
VTP Management Domain: tmi.com
Primary Management Address: IP 192.168.0.1,
Secondary Management Address: IP 192.168.0.1,
Addresses:
          IP 192.168.0.1
          IP 192.168.0.1
Interface: gi50, Port ID (outgoing port): GigabitEthernet1/0/14
Holdtime: 138
Cop
Duplex: full
Native VLAN: 999
SysObjectID: 0.0
Addresses:
          IP 192.168.0.1
          IP 192.168.0.1
MO02#
Highlighted
Advocate
Hi Truoc, so it is the problem, your smb switch native vlan is 1 when it should be 999. How to fix it would be to delete the link aggregation on the smb switch then recreate it. Before making other commands for vlans you need to use the command
then you may do your additional vlans
switchport trunk allowed vlan add .... .... .... ....
When you create a LAG on the smb switch it cannot be a member of any vlan so it will default to vlan 1 which is where your untag packet resides. So once the lag has been created you need to modify the default vlan first then tag your packets.
Also if you don't want to delete the lag I believe you can remove all vlans off the lag then modify the default vlan
switchport trunk allowed vlan remove ....
-Tom
Highlighted
Beginner
Dear Mr. Tom,
I try to do as your guide for step by step but still can't.
1. If I setup 1 port to native vlan 999, is it work. I saw PVID in web config of this port displayed 999
2. If I setup LAG to native vlan 999 after that I setup 2 port to LAG, I saw the PVID in web config is: LAG have PVID 999, port have PVID 1. Still have same CDP message.
Now, I try to setup default vlan to 999 and reboot the switch, all is work. No CDP message showing...
So I don't know this setup good or not?! Please advise!
Thank and best regards,
Truoc
Highlighted
Advocate
Hi Truoc, the default vlan should not make any difference.
Here is how I configured my switch-
config t
vlan database
vlan 999
int fa01
channel-group 1 mode on
int fa02
int po1
end
wr mem
This makes my etherchannel vlan 999 untagged without error.
-Tom
Highlighted
Beginner
Dear Mr. Tom,
I reset my SG300 to default and do the setting same as your config, result is: po1 untagged vlan 999 but interface gi1 and gi2 still untagged vlan 1.
Best regards,
Truoc
Highlighted
Beginner
I have the same situation,
I have the same situation, but all vlan is the same. Could you help me?
switch42f189#show interfaces switchport ge52
Port : gi52
Port Mode: Trunk
Gvrp Status: disabled
Ingress UnTagged VLAN ( NATIVE ): 1
Port is member in:
 1                  1                  Untagged          Static
 2               Name 2                 Tagged           Static
 40              Name 3                 Tagged           Static
 50              Name 3                 Tagged           Static
 51              Name 4                 Tagged           Static
 52              Name 5                 Tagged           Static
 53              Name 6                 Tagged           Static
 54              Name 7                 Tagged           Static
Forbidden VLANS:
Vlan               Name
switch42f189#12-Jan-2014 18:24:35 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi52.
Highlighted
Beginner
Everybody find a solution to
Everybody find a solution to this problem ?
In fact, i have the same problem.
Highlighted
Beginner
anyone found a solution? have
anyone found a solution? have a similar problem but on a sg350 -> 3750
Highlighted
Beginner
I assume, VLAN999 is a unused "dummy" VLAN to tag-all VLANs used for productive traffic at the Catalyst. * at the SG-Switch you could set the port easily to "Native-VLAN: None" and add a "List of tagged VLANs" to the Trunk * at the Catalyst there is always a Native-VLAN at a trunk [unless you configure tag-all] => avoid the useless error-log-message at the SG-Switch using conf t (config)#no cdp log mismatch native
