08-01-2012 03:24 PM
Inline power (PoE)
Can some one confirm PoE Spec's and a little confused reading the spe'c
the spec say
●All 24 PoE ports on the Cisco Catalyst Express 500-24PC can supply up to 15.4W
(IEEE 802.3af standard maximum) of power over Category 5 cable, for a total of 370W
of inline power.
● Both the IEEE 802.3af PoE standard and Cisco prestandard inline power are supported
I have cisco 7940G witch are Prestandard so this switch will power the Phones on PoE ?
does not say it will supply PoE for Prestandard Phones just say its Supported
Solved! Go to Solution.
08-01-2012 06:32 PM
Hi Colin,
Yes, the switch will power prestandard 7940s. Specs state it works on both 802af and cisco prestandard poe.
Best,
David
Please rate helpful posts and identify correct answers.
08-01-2012 06:32 PM
Hi Colin,
Best,
David
