CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
155
Highlighted
Participant
Cisco 220 switches in ring topology
Greetings to all,
Does cisco 220 smart switches support ring topology connectivity.
Can we connect 7 220 switches in ring topology with end of ring being connected to core 350x switch
2 REPLIES 2
Highlighted
VIP Advisor
Re: Cisco 220 switches in ring topology
Ring Topology required different segment. like provider ?
what is the use case here for Ring Topology ?
These are small business switches - so wont be capable of support that as per i know.
Let me know what is the use case ?
BB
*** Rate All Helpful Responses ***
Highlighted
Participant
Pls refer attached PIC.
Customer is not agreeing to buy a fiber switch to use as core. So our management is asking if we can use ordered 350x-48P layer 3 switch as core and then connect it 7 220 access switches in 1-4th floors using single mode fiber in ring topology.
Can STP be used for this?
